Version 1.0.2
Oberhesse wrote
The Temperature Monitor plug-in monitors the hard disk and system temperature in the background and displays a warning if a user-defined threshold is exceeded.
The system temperature is determined according to sensor availability (CPU or board).
A running log can be generated and the temperature statistics displayed.
The temperature statistics can also be used to record the usage behavior of the box; I recommend the "10-minute" option for this.
