<?xml version="1.0" encoding="utf-8" standalone="yes"?>
<!-- Automatically generated by the e2m3u2b -->
E2m3u2bouquet IPTV suppliers config file
Add as many suppliers as required
this config file will be used and the relevant bouquets set up for all suppliers entered
0 = No/False
1 = Yes/True
For elements with <![CDATA[]] enter value between empty brackets e.g. <![CDATA[mypassword]]>
<config>
<name>Сборка</name><!-- Supplier Name -->
<enabled>0</enabled><!-- Enable or disable the supplier (0 or 1) -->
<settingslevel>1</settingslevel><!-- GUI settings level (0 - simple, 1 - expert) -->
<m3uurl><![CDATA[
https://dl.dropbox.com/s/qepct7b4tj3telh/ABC.m3u8]]></m3uurl><!-- Extended M3U url -->
<epgurl><![CDATA[
http://epg.it999.ru/edem.xml]]></epgurl><!-- Forced loading events from the specified XMLTV EPG URL -->
<streamtypetv>5002</streamtypetv><!-- (Optional) Custom TV stream type (e.g. 1, 4097, 5001, 5002 or 8739) -->
<gstreamer>1</gstreamer><!-- (Optional) Stream type: 0 (no buffering), 1 (buffering enabled) or 3 (progressive download and buffering enabled) -->
<progressive>0</progressive><!-- (Optional) EXT3_PLAYBACK_PROGRESSIVE (0 or 1) -->
<livets>0</livets><!-- (Optional) EXT3_PLAYBACK_LIVETS (0 or 1) -->
<buffersize>8192</buffersize><!-- (Optional) GST_BUFFER_SIZE buffer size in kilobytes -->
<bufferduration>0</bufferduration><!-- (Optional) GST_BUFFER_DURATION buffer duration in seconds -->
<multivod>0</multivod><!-- Split bouquets into seperate categories (0 or 1) -->
<usenickname>0</usenickname><!-- Create bouquet name from provider name and group name (works if you have only one provider) (0 or 1) -->
<restrcat>0</restrcat><!-- Apply restricted categories filter (0 or 1) -->
<allbouquet>0</allbouquet><!-- Create "All in one" bouquet as separate bouquet if multivod enabled (0 or 1) -->
<picons>0</picons><!-- Automatically download picons (0 or 1) -->
<usepil>1</usepil><!-- Use PIL to optimize loaded channel picons (0 or 1) -->
<piconsalt>1</piconsalt><!-- Forced loading of piсons from the specified XMLTV source (0 or 1) -->
<sortmethod>0</sortmethod><!-- Sorting method for playlist content (0:default, 1:alphabet, 2:custom) -->
<abgroups>0</abgroups><!-- Sort group names alphabetically (0 or 1) -->
<abchannels>0</abchannels><!-- Sort channel names alphabetically (0 or 1) -->
<newbroadcasts>1</newbroadcasts><!-- Create "New broadcasts" bouquet (0 or 1) -->
<streamlink>0</streamlink><!-- Use streamlink proxy syntax (if this plugin is installed) when creating serviceref entries (0 or 1) -->
</supplier>
</config>
