Скины Shadow WQHD (DreamOS)
Shadow WQHD Skin Update : .05.08.23 v1.0 r32
- some small changes on some screens
- dbackup config screen (config screen only) with chinned
- small optical adjustments at Emby
thanks zombi
Shadow WQHD Skin Update : .19.08.23 v1.0 r35
- Default 3 fonts can now be selected per style (font 3 is the original Dreambox font which should also contain many languages)
thanks zombi
Shadow WQHD Skin Update : .22.08.23 v1.0 r36
- New BluePanel tile view for the single-line list.
- Minor font fixes for the extra switchable fonts and time displays.
thanks zombi
Shadow WQHD Skin Update : 01.09.23 v1.0 r38
- MultiEPG's unified (default and EDM screens)
- Changed default second infobar and added new information in it
- internal
thanks zombi
Shadow WQHD Skin Update : 02.09.23 v1.0 r39
Thx @zombi
Shadow WQHD Skin Update : 03.09.23 v1.0 r40
- EDM default channel list fine tuning and text font made a little larger + additional information easier to read (even if there is a background image underneath that is light).
- in the default without EDM and no banner channel list, the text font is also enlarged a little
thanks zombi
Shadow WQHD Skin Update : 10.09.23 v1.0 r41
New update:10.09.2023
- weiteres schaltbares Hauptmenü (über Styles auswählbar)..
- original Movielist Screen und den AdvancedMovieSelection_Preview_noCover umgestalltet (oben rechts jetzt mit Pig Bild und Farbverlauf)..
- weitere kleinere Anpassungen hier und da in den Screens..
Shadow WQHD Skin Update : 17.09.23 v1.0 r42
- Another switchable channel list can be selected via styles (Small)
- The switchable transparent main menu was adjusted/changed a little again
- some internal adjustments
thanks zombi
Shadow WQHD Skin Update : 24.09.23 v1.0 r43
- single-line Bluepanel tile view changed again and unified with the Info PIG screens)
- many internal adjustments
thanks zombi
Shadow WQHD Skin Update : 28.09.23 v1.0 r44
- GPT BootPlugin eingeskinnt..
- einzeilige Bluepanel Kachelansicht nochmal Feinarbeit..
- TV Spielfilm Info Screen umgestalltet und verschönert..
- TV Spielfilm -TV-Programm und TV Spielfilm-Tipps Listeninhalt sowie Screen ein wenig angepasst..
- Vod und Emby Player ,Play-Pause und Sprung Icon ein wenig angepasst (jetzt mit einem Runden leicht black-transparentem Hintergrund)..
- weiteres an einigen Screens..
thanks zombi
Shadow WQHD Skin Update : 14.10.23 v1.0 r46
- Adjustment for current Emby update
- internal
thanks zombi
Shadow WQHD Skin Update : 15.10.23 v1.0 r47
- Adjustment to the player time format now in the movie players as an hour display
- Filmstrip, screens redesigned to better suit the players used
- Some icons have been added or changed
- internal
thanks zombi
Shadow WQHD Skin Update : 28.10.23 v1.0 r50
- PVR State an die Playeroptik angepasst..
- MinuteInput an die Playeroptik angepasst..
- Bitrateviewer Screen mit eingeskinnt..
- ein paar Veränderungen bei dem Multiepg Screen..
- kleines optisches Gimmick bei der gcommanderlist_list_8_1 eingebaut (Listenansicht des GP )..
- so einige kleindere interne Anpassungen hier und da..
Thx @zombi
Shadow WQHD Skin Update : 03.11.23 v1.0 r52
- Fix für no Banner Kanalliste und Listenansicht bei All und Ordner ( jetzt einzeilig mit mehr Einträgen pro Seite )..
- kleinere interne Anpassungen..
Thx @zombi
